MIDI Mote Mapper Patch
Vincent
Unread post by Vincent » 01 Mar 2007, 02:32
Hello.
A new topic specially for that stupid patch!
I forgot to explain a very important purpose of that patch: it's done to be used in correlation with a keyboard splitter. And when you split, you have shorter keyboards... well, not with the mapper!
Example with two splits (but you can have 3 splits with the Range Fader Module):
- Split 1: from 0 to 63, Octave = 1
- Split 2: from 64 to 127, remap all black keys of the 2 first octaves (64 to 88 = 10 keys) to 53...62.
As you see, that can easily expand and overlap splits for interesting instrumentation.
Not really shorter keyboards, but much more complicated... Well, as you said, Olivier, ?Everything has a cost...?
Waiting I'll manage to implement the note range filter in the script (it does not work with modules, no polyphony), this MIDI Mote Mapper Patch needs a small free Midi plug-in. It's all in this tiny ZIP (7 days until now).
Don't tell me you don't need such a stuff, I'll believe you.
Vincent
Unread post by Vincent » 03 Mar 2007, 04:15
Well boys, some news of my headaches.
I'm just wondering why such a simple thing is so complicated.
In SynthEdit there is an existing module called Midi Filter. Well, OK.
I just take it, two Lists to put limits on the note filter, two I/O, and make a DLL (≈0% CPU).
And use it in Usine.
It's just perfect. I can sleep now.
Please don't wake me up too early today with your crazy synths!
Unread post by senso » 03 Mar 2007, 11:07
Today 04:15:12
You never sleep?
Vincent
Unread post by Vincent » 03 Mar 2007, 16:40
Have you ever met hunters?
Unread post by senso » 03 Mar 2007, 18:45
yes the Headhunters!
Vincent
Unread post by Vincent » 04 Mar 2007, 16:01
Oh, yes!
But I'm not that kind of hunter. I maybe should have say "trapper".
Unread post by senso » 04 Mar 2007, 20:11
PS:In the next version all midi transform will work for polyphonic messages.
Vincent
Unread post by Vincent » 04 Mar 2007, 20:22
senso wrote:PS:In the next version all midi transform will work for polyphonic messages.
Yeah! Good news, as usual..
Thanks.
