Padayan
Unread post by nay-seven » 01 Apr 2010, 13:18
A simple tool : 4 samplers , 6 samples for each on
A pad for each sample , 2 mode for the pad :
1_moment mode = will play momentary the sample as long you press the pad , except if you press and move your finger inside the pad
2_moment off = let play the sample in a classic toggle mode
Options button open a new window with a filter and a mixer.
I will do a wiki page soon.
check a little Video demo
Was a little try to use the great matrix with a momentary option , for a pad tool
Unread post by nay-seven » 01 Apr 2010, 17:40
video demo link added.in the first post...
kara
Unread post by kara » 01 Apr 2010, 18:12
nice demo :cool:
k
Unread post by bsork » 01 Apr 2010, 18:17
+1 :)
Unread post by nay-seven » 17 Aug 2010, 13:58
updated to v2 ( need matrix pack 1.2 )
check the different layout in the first post
waolelaid
Unread post by waolelaid » 18 Aug 2010, 04:10
always at the top , nice ;)
Friedrich Nietzsche
Unread post by nay-seven » 13 May 2011, 10:34
updated to v3 : add exclusive mode on row and simplify the momentary mode
ErotiCore SteNch
Unread post by ErotiCore SteNch » 13 Aug 2011, 14:16
been toying about with this one and i really like it.
one thing though i get alot of clicks,might just be the samples it came with though
ErotiCore SteNch
Unread post by ErotiCore SteNch » 13 Aug 2011, 21:33
been getting alot of fun out of this,but i noticed that when i use 2 instances of this in a workspace,more often than not its only 1 instance that work
and the one that dont "work"wont give any sound no matter what i do,it also doesent help to re-load a new instance,dont know if it just happens here though.
btw i havent changed any samples or other settings in the patch
Unread post by nay-seven » 13 Aug 2011, 21:52
this kind of things generally happens when you use buses , cause you can have conflict between 2 instances, but i don't use buses in this add-on..have you check on a fresh workspace..?
ErotiCore SteNch
Unread post by ErotiCore SteNch » 14 Aug 2011, 01:54
one other thing is it possible to somehow get the name of the sample "attached"to the different pads shown over the pads
i know they get shown in the waveform when a pad is pressed,but if it was possible you didnt have to remember where each sample is placed?
just a thoguht
Unread post by nay-seven » 14 Aug 2011, 09:12
yes, it's a good suggestion
ErotiCore SteNch
Unread post by ErotiCore SteNch » 14 Aug 2011, 15:32
nay-seven wrote:yes, it's a good suggestion
so it is possible via some text module perhaps?
ErotiCore SteNch
Unread post by ErotiCore SteNch » 14 Aug 2011, 15:46
btw is it ok if i try to modify this for my own needs and as a learning experience?
i wanna try to look into making a "time-detector(i belive i have seen a module for this somewhere)so when the main bpm gets changes the sounds follows the tempo
one other thing i have thought about checking out if would be possible is a way to combine 2 of these into 1 to get a bigger matrix but with the same size cells as they have now
heres a screenshot,something like this but with the 2 matrixes becoming 1 bigger matrix
http://shup.com/Shup/528160/livetriggerpadproject.jpg
Unread post by nay-seven » 14 Aug 2011, 16:03
of course all add-ons are here to help user to learn and can be modified an improved
Users browsing this forum: No registered users and 31 guests
