Hi
This is my question of the day.
i'd like to create a line step module which follows the position of one sample
i manage to apply the same duration (it's easy) but if i wire the position of the sample on the step position of a point curve (for example) it doesn't care about the duration and navigate step by step (that is logic).
How can i do to always be at the same time (and not position) between my sample and my point curve ?
thank you
sample playing position= step position
martignasse
hi joffo78,
something like this ?
Hum sorry but i'm afraid it doesn't work ! it switch between two position in this case. I don't understand why
if i understand correctly , you have to set the sampler and the curve module to synchro =button
martignasse
oups, nay is right, synchro =button for both.
sorry
sorry
