Right click in IB?
Clearscreen
Unread post by Clearscreen » 25 Mar 2010, 00:51
I'm using a touchscreen for a performance and if I leave my finger on the screen too long I get the right click menu - it'd be nice to be able to enable this for building and disable it for performing. Any solution Senso?
Clearscreen
Unread post by Clearscreen » 25 Mar 2010, 01:31
Had another thought on this - when in fullscreen IB mode (after pressing '+') maybe have right click disabled and have it enabled in regular IB mode (ie when the console etc is visible)... hopefully I've explained that well enough? A bit scattered at the moment - got a big performance to do tonight.
Unread post by senso » 25 Mar 2010, 08:26
As I can remember, under Win7 you can disable it somewhere in the configuration panel / touch screen options.
Clearscreen
Unread post by Clearscreen » 01 Apr 2010, 00:33
Unfortunately I'm still on XP, but I take your point - I might have a look in the mouse settings I guess... Does that mean nothing can be done in Usine?
Unread post by senso » 01 Apr 2010, 08:23
absolutely nothing, because it's a Windows behavior.
Clearscreen
Unread post by Clearscreen » 04 Apr 2010, 02:51
DOH! :(
Oh well...
