Usine V5.13beta
Announcements
Unread post by senso » 18 Mar 2010, 14:58
[large]version 5.13 beta[/large]
Important details corrected on the v5.12beta.
This version fixes most of reported bugs and implement new important features.
Can be considered as the first "service pack" of the V5 and because of all the changes It is still a beta version.
Download highly recommended.
[large]fixed bugs
[/large]
- the midilearn on switches doesn't work properly
- various Sequencer refresh issues
- the filter string in the browser can't contain 'space' character
[large]improvements
[/large]
- new /Crashes folder where are stored last modified patches and log files for an easy recovery after a crash
[large]version 5.12[/large]
[large]improvements[/large]
- You can now send several audio flow in the same Audio Bus.
- New Analysis/Partial Tracker Module can replace the zero crossing module in the AudioToMidi Patch.
- new perfect synchro option in the setup and globally a better synchro in the sampler.
- the Audio volume contains a new “Mute” inlet
- better resampling quality in sampler especially when the pitch is smaller than -2 octaves
- various GUI details in the sequencer
- new "unSelect all" menu in the sequencer.
- You can drop VST's directly in the sequencer
- improvements on Button module, which now has a max/min value
- New internal help window.
- the On Activation module works when the position reaches the beginning of the patch in the sequencer.
[large]fixed bugs[/large]
- almost all cameras incompatibility issues in the Video Detect Module DX
- the sequencer insert patch control panel is always invisible
- various VST denormalization bugs
- no more flicker effect in the Video Detect module
- graphic Freeze issues in the sequencer.
- the mouseMove now works in Sequenced Switches module
- various bitmap chaining issues
- the 'find in patch' command doesn't work in the Free version
- the last character is truncated in osc tag 's'
- new Midi-Arpeggiator script
- various reported bugs
Thanks to all beta testers for their help.
artificial
Unread post by artificial » 18 Mar 2010, 23:39
omg, that's unbelievable, how fast you work, olivier!!! :)
thanks once again!!
gurulogic
Unread post by gurulogic » 19 Mar 2010, 21:06
senso wrote:- You can now send several audio flow in the same Audio Bus.
This is a fantastic new feature! This has opened up a great way for me to easily assign multiple instruments to sub-mixes without having to use a trillion buses! Thanks! (btw, is there any limitations I should be aware of?)
Unread post by senso » 19 Mar 2010, 21:12
there is no particular limit!
gurulogic
Unread post by gurulogic » 19 Mar 2010, 22:19
I'm having some trouble conquering the buzzing sound that can happen from a receive bus when changing the name of a send bus. I have tried triggering a quick name change of the receive bus to hopefully clear the "buffer" but the buzzing continues when the receive bus resumes it's normal name.
Any ideas?
edit:
I guess I can call this a solution for now...seems to work. Code name "buzzkill"! :)
Or even better...
(ok, I'll stop spamming the beta thread now ;) )
Unread post by woodslanding » 21 Mar 2010, 08:00
you should be using the audio busses--they have automatic protection for this now!
gurulogic
Unread post by gurulogic » 21 Mar 2010, 10:13
I am using the audio buses...If I change the name of a send bus, the receive bus can continue to receive "nothing" and make a buzzzz sound.
Unread post by woodslanding » 21 Mar 2010, 19:16
so your screenshot is out of date?? It shows data busses! You do know about the new audio only busses? They are purple like the audio ins and outs.
I thought senso fixed this with the new buss objects....
but before he did that I took most of the buss naming out, so I haven't tested it much.
gurulogic
Unread post by gurulogic » 21 Mar 2010, 23:44
Oh what the crap,..how did I end up doing that and not even noticing!? Data buses!? Damn good thing I don't work for NASA...
Sorry for the misinformation...
Users browsing this forum: No registered users and 250 guests
