I'd like to reverse the value of a fader with a min max 0-100.
I've tried to set the fader min value to 100 and the max to 0 but it doesn't work.
how can I do that ?
Reverse fader value
Fader with min 0 and max 100 goes to an (A-B) module where you set A=100 and B the input of your fader.
Is that what you want ?
k
k
yes kara , the easiest way
check also the
data/data manipulation/Change Scale patch...if you need more esoteric scales..
check also the
La Tenaille
was too simple
The change scale patch is a nice feature, I have to keep it in mind.
