Usine V5.12
Announcements
Unread post by senso » 17 Mar 2010, 20:01
[large]version 5.12[/large]
This version fixes most of reported bugs and implement new important features.
Can be considered as the first "service pack" of the V5 and because of all the changes It is still a beta version.
Download highly recommended.
[large]improvements[/large]
- You can now send several audio flow in the same Audio Bus.
- New Analysis/Partial Tracker Module can replace the zero crossing module in the AudioToMidi Patch.
- new perfect synchro option in the setup and globally a better synchro in the sampler.
- the Audio volume contains a new “Mute” inlet
- better resampling quality in sampler especially when the pitch is smaller than -2 octaves
- various GUI details in the sequencer
- new "unSelect all" menu in the sequencer.
- You can drop VST's directly in the sequencer
- improvements on Button module, which now has a max/min value
- New internal help window.
- the On Activation module works when the position reaches the beginning of the patch in the sequencer.
[large]fixed bugs[/large]
- almost all cameras incompatibility issues in the Video Detect Module DX
- the sequencer insert patch control panel is always invisible
- various VST denormalization bugs
- no more flicker effect in the Video Detect module
- graphic Freeze issues in the sequencer.
- the mouseMove now works in Sequenced Switches module
- various bitmap chaining issues
- the 'find in patch' command doesn't work in the Free version
- the last character is truncated in osc tag 's'
- new Midi-Arpeggiator script
- various reported bugs
Thanks to all beta testers for their help.
Unread post by 23fx23 » 17 Mar 2010, 20:20
wou oouuu soo coool thanks!!!!
ethnix73
Unread post by ethnix73 » 17 Mar 2010, 20:33
:cool: As usual
Seb.Dub
La Tenaille
Unread post by La Tenaille » 17 Mar 2010, 21:15
Unread post by nay-seven » 17 Mar 2010, 21:35
great !
thanks a lot !
gurulogic
Unread post by gurulogic » 17 Mar 2010, 21:45
Awesome! Lots of new stuff, and just when I have some time again! :)
martignasse
Unread post by martignasse » 17 Mar 2010, 21:59
good job Senso :cool:
Floego
Unread post by Floego » 17 Mar 2010, 22:05
thank you :)
artificial
Unread post by artificial » 17 Mar 2010, 22:12
Thank you for your this update and for sure, for all your work, Olivier!
Unread post by grego mondo » 17 Mar 2010, 22:23
allehlu senso !!
gurulogic
Unread post by gurulogic » 18 Mar 2010, 03:35
senso wrote:- the Audio volume contains a new “Mute” inlet
Guess I don't need to use this anymore ;)
iococoi
Unread post by iococoi » 18 Mar 2010, 09:02
thumbs up!
video tracker runs perfectly...thanks!
franck
Unread post by franck » 18 Mar 2010, 09:27
Hello Olivier,
Whaou, A lot of good things in this update, thanks very much for this news.
franc et ses amis
Users browsing this forum: No registered users and 316 guests
