Our Favorite Improvements For Usine Sequencer
franck
Unread post by franck » 16 Mar 2010, 11:57
Hello Olivier and Usiners,
Here we are three Usiners using just Usine sequencer and we have some requests very importants for us...
There is a list, we know that some requests are already asked...
- A new path in interface option just for WKP files
- DUPLICATE TRACK in menu
- DELETE TRACK in menu
- MOVE TRACK (up/down) in menu
- possibility to COPY and PASTE patchs to another WKP
- DESELECT ALL PATCHS in menu
- On the Track name left column if The Track is selected Changing the Track name color
in white color, similar to the Track Mixer.
- Possibility to select one patch and when we selected another patch with mouse left clic + Control key
all patch between these two patch are now selected on all Tracks (good for copy and paste).
- When clic on a patch, if the mouse is on the top of the name curve (volume, user 1 ...) I dont want
to change immediatly the active curve. First clic to select a patch and a second clic to change the active
curve (if is necessary).
-When a patch is selected, when mouse is over a curve points (mouse is double arrow), possibility
to see the value of active curve without move a curve point. Value follow the mouse position on the curve.
- In Piano roll Sequencer possibility to move Head PLAYER in the Piano Roll Time line, mouse clic, like in
master time line. If I move Head Player in Piano roll, Obviously the master Head Player following.
- In Piano Roll possibility to Hear sounds when mouse clic on the right keyboard.
- An option for the piano roll, to see names keys instead the classic paino keys, with possibility to
load, save an create map names. I KNOW this is a HARD OPTION...
- A new module who dectect the Play Head is begins to read a patch ( 1 output toggle) and when is a
end of the playing patch (another output toggle).
Thanks to Olivier and the active community in this forum, and good music and long live to USINE.
Franc, richard et lionel
Unread post by senso » 16 Mar 2010, 18:09
[large]interesting suggestions to add in my (already huge) TODO list...[/large]
Clearscreen
Unread post by Clearscreen » 17 Mar 2010, 02:35
+1 - it'd be great to see this stuff in the sequencer.
Not sure it hasn't already been mention, but it'd also be nice to drag and drop a vst onto a track and have Usine create a patch based around the vst. I'm not sure that the IML couldn't be used for this already? I know at the moment dropping a vst doesn't do anything...
franck
Unread post by franck » 17 Mar 2010, 09:13
Hello Olivier,
We Know your TODO LIST is full and the Usine Sequencer is not a priority for a lot of users but the sequencer is the most important for us. We see threre is not a lot of answers with our post but we use Usine all days at house and in live. We continue to be patient.
Franc et ses amis
gurulogic
Unread post by gurulogic » 17 Mar 2010, 09:50
I agreee, more advanced sequencing could be a good future diection for Usine.
Unread post by senso » 17 Mar 2010, 14:16
just few precisions.
every user is important and it's more a problem of time than "priority"!
Will be implemented as soon as I can.
I don't know how to do that, actually the best way is to export the wkp and load exported patches separately.
implemented
implemented
I asked before, I prefer the selection rectangle. Will be implemented as soon as I can.
I'll suppress the curve list, replaced by a popup menu.
Internally not easy.
let me think about
implemented
not necessary so hard...
the "on activation" module works in this case.
but conceptually for the end it's totally impossible because by definition the patch is not calculated... I can create a "on end' module like "on activation" but will be useless because as the patch is OFF it will not be able to receive it!
Unread post by senso » 17 Mar 2010, 14:19
implemented
