my christmas gift ( joystick patch+dll tool up to 16 buttons)
Unread post by nay-seven » 23 Dec 2008, 17:01
patch +dll ( to install in your vst folder ), usefull to use a joystick as controller .
add 3 axis , Z-rotation, 2 direction pad , 2 sliders, and 16 buttons support
must be compatible with most of gamepad and big joystick ..
Joystick Selector - Selects which joystick to assign ( up to 8 )
Deadzone % - Size of non-responsive zone at dead center of X-Y axes,as a % of total range (0 to 50%).
Smoothness - Higher values give smoother response, at the cost of a small amount of latency. Range: 1 - 5.
button 1 and 2 have a switch option ( easy to copy to other buttons..)
enjoy
(updated )
héliouk 6
Unread post by héliouk 6 » 25 Dec 2008, 20:04
cool...i'm gonna buy some joystick to try this...thanks ...
gercha1
Unread post by gercha1 » 08 Mar 2010, 17:26
hi nay seven
I try your joystick patch with a dance pad
i got a lot of latency
what are you mean with the patch "more sensitive " ?
thank in advance
gercha
Unread post by nay-seven » 08 Mar 2010, 18:47
sorry gercha1 , it's an old patch and don't even remember what was this "more sensitive " patch..i feel stupid..and i've delete this sentence..
about latency , i can't do more , depending of windows , the joystick, your computer and so....
sorry again
gercha1
Unread post by gercha1 » 08 Mar 2010, 19:11
ok , no problem,
i try to find myself a solution,
and thanks for usinome lite,
i try it just now !!!
nice tool !!
gercha1
