Usine V5.10
Announcements
Unread post by senso » 06 Mar 2010, 17:30
[5.10]
Important improvements especially a new Video Tracker module more efficient and an off-line help system.
The off-line help is included in the package but can be easily upgraded independently of the main program.
improvements
- new Video Tracker Module using DirectShow layer. More efficient.
- color inlets have now a different color
- 'OFF-line' wiki/help system
- new Option 'Conductor isolate' in patches and sub-patches. To isolate parameters from a conductor recall.
fixed bugs
- lines, steps, switches and curve modules give an error and won't load when choosing 128 faders
- the position of the ball in XY module is not stored in the conductor
- logical operators now work with array's
- preset Isolate enabled for a sub-patches does not save
- the aux input of the additional Input module doesn't work
- few other details
Floego
Unread post by Floego » 06 Mar 2010, 17:51
Thanks for this new version!.
I need help on upgrading from v5.08 to v5.10. This new version is a lot bigger in size than the previous one, so I would like to know if I need to upgrade every folder inside usine standalone or not?. What are the upgradable modules?. Do I need to backup something inside the usine folder prior to upgrading?.
Thank you in advance,
Floego.
Unread post by senso » 06 Mar 2010, 17:57
You should download all the package.
Just backup the following files
Default-settings.ini
Default-Remote.remote
Default-Master.master
Floego
Unread post by Floego » 06 Mar 2010, 18:24
Thanks!!
Unread post by 23fx23 » 06 Mar 2010, 22:08
yesssss cooool
ethnix73
Unread post by ethnix73 » 07 Mar 2010, 00:00
Thanks mister senso!
Seb.Dub
artificial
Unread post by artificial » 07 Mar 2010, 11:44
thanks for the update, olivier! :)
gurulogic
Unread post by gurulogic » 07 Mar 2010, 11:45
As always, thanks for all the hard work!
Unread post by grego mondo » 08 Mar 2010, 02:46
thanks !
artificial
Unread post by artificial » 08 Mar 2010, 15:06
I can't load the video capture dx module. Everytime I try to open it, it crashes Usine... btw, I'm on Vista 32 bit with Asio4all.... any suggestions?
La Tenaille
Unread post by La Tenaille » 09 Mar 2010, 21:50
senso wrote:- new Option 'Conductor isolate' in patches and sub-patches. To isolate parameters from a conductor recall.
That ... is a fucking good new! Simply magic for my use.
Thanks a lot, christmas never stops :)
