http://sensomusic.com/forums/uploaded/Wspace.zip
tell me what you think ...
OK is here my Wspace about FCB 1010
oups it seems like the link doesn't works ... but you should just go to uploader and download it.
have fun
have fun
La Tenaille
Nice, thanks for sharing.
I've had a first look... hard to dive in a complete workspace !
The first big difference is you only have 1 instrument in... I have 7 and use a track per instrument. Your configuration - 1 track per FX - is more friendly of course.
Where / how can I locate your FCB midi learns ?
- nay-seven
many thanks to share grego ! it's good job !
2 things quickly before going to work :
you can reduce a lot the weight ( 60Mb )of this zip file by deleting the " -old " files..not useful here
i feel that you can extract some addons here..
the way you patch the wii, the way you store preset with text list..for example could be useful as addons for others..?
thanks,
to La Tenaille :
Maybe if you don't use differents instruments at the same time you still can use my patch, just change the input of the first track for each conductor ... you also can use the track with sampler, theremin and wii and use this patches actives for only a moment ...
I putted a "txt" file with the fcb1010 Midi configuration, if you want I can explain more ...
to Nay-seven : sorry, I saw the "-old" file and thought I didn't select it to be compress for the zip file.
yes, I'll extract the Wii patch and the text list (conducteur as we say down in france).
I feel I can optimize the set of preset manager, I guess a better version will be updated in a week or two ...
to La Tenaille :
La Tenaille
in fact I use the whole instruments realtime
I'll have a look to the .txt I missed on Monday.
