Hello, tried to export my workspace with the fcb1010, wii ...
it works fine but the workspace weight 26Mg !! ... without the audio of course.
It seems really heavy isn't it ?
What can make it so heavy ?
Is it conductors (13) and preset memory (5) ?
my workspace is
track 1 tuba source (with compressor)
track 2 Pitch VST
track 3 Disto VST
track 4 Wah VST
track 5 Vb VST
track 6 Pure sound (with Eq)
track 7 Theremin, Wii & Sample player
track 8 delay VST
track 9 Synchro and master of IB
Can I upload it ?
and maybe somebody can explain me such a weight ?
too Big Workspace
martignasse
Hi grego,
It's kind of big workspace, but with lot of tracks and lots of conductors entries it's maybe normal.
Conductor make a photo of the whole workspace for each entry, so...
zip your wkp (you'll see a great size reduction
) and upload it, i'll have a look, at least to explain why this size.
i know it's a little work but, another thing you can try is to make a lite version of your work space but only with heliosII as vsti and Usine patch as vst
This way , more people can use it directly and this help to concentrate to the way you use the FCB..?
you're right, I do a "universal" version ...
Users browsing this forum: No registered users and 111 guests
