Colour coding of patches?
Unread post by bsork » 09 Jan 2007, 09:21
Would it be possible to make the background colour of the patch name user selectable? If this is already possible, I haven't found out how; to me the applied colours seems more or less random.
This would make it possible to create some kind of colour coding for different types of patches, making the right patches a little bit easier to find.
...and by the way: I've forgotten to say thanks for the latest updates!
Unread post by senso » 09 Jan 2007, 09:37
Good suggestion!
It's impossible right now but it should not be a real problem to implement.
I put it in my TODO list.
Unread post by bsork » 09 Jan 2007, 09:43
Thanks!
Jake Johnson
Unread post by Jake Johnson » 14 Feb 2007, 17:12
You can create something similar to what you want, now, although it means recreating the patch name by adding a text box and then changing its background color :
1. In the patch, add a Text module from the Interface Design folder. Click on the newly added text box.
2. To the right, in the interface design slot, click on Edit, double-click on the default "TEXT" and type over it to name the patch, or use the space bar to enter 5-6 lines of blank space. Or enter the text and then use the space bar to add new blank lines. Click on OK.
3. Click on Color, choose the color you want, and click on OK.
There are of course drawbacks--
1. You can't put buttons, etc, over this newly colored area, since it's a text box. On the other, hand, if are using buttons, etc, you can color the buttons on each patch, instead of, or along with, the text box.
2. This procedure doesn't color the actual patch name at the top of the patch display, as you wanted, and it creates a duplicate of the patchname, but you can create a larger patch name this way, with larger text and a larger colored area that you can see more easily from a distance... In other words, it's actually better than just changing the color of the patch name.
Unread post by senso » 14 Feb 2007, 20:51
The change color function is implemented in the next version.
Don't you think that your suggestion can be a little tricky?
Unread post by bsork » 15 Feb 2007, 08:41
Hi Jake, I have already did something similar to what you're suggesting in a patch or two and it's working just fine. Nice to have, especially when I'm not directly in front of the PC.
What I wanted (and get in the next version), was a way of colour-coding patches to make navigating in a complex workspace a little simpler.
Olivier: what about making the new text field module have colour and size options just like the existing post-it?
Unread post by senso » 15 Feb 2007, 08:54
Good suggestion.
thanks
Vincent
Unread post by Vincent » 08 Mar 2007, 03:44
bsork wrote:Would it be possible to make the background colour of the patch name user selectable?
That's of course a very good suggestion, very useful.
And, if it's not ask for too much, that color could be, by default, the same for the patch in the Sequencer time-line, ie. you could choose it indifferently in the track-view patch contextual menu (just like now) and/or in the Grid view (or Live view) on the label (Bj?rn's suggestion).
That should be closely examined: if colors are supposed to identify categories of patches and you create a track for patches of the same category, it may be visually confusing to have here many different blues or greens. In the other hand, it's much more convenient to see your patch with the same color when you switch from F1 to F2 (as you build your track), and when the Sequencer Live Mode updates, in live situation, you exactly know where you are just with a glance at colors.
Bj?rn will soon also begin to use tracks and I think he will have good suggestions for that point too. Anyway, if it's possible to change those colors in both views, we can choose the same or not... What do you think? Not too complicated?
Small detail about colors: Why is it not possible to save my personal palette? Is it a bug of my OS?
Unread post by senso » 08 Mar 2007, 08:09
thanks for your comments
I need time to think about the color feature.
we'll find something...
Not yet implemented.
Users browsing this forum: No registered users and 78 guests
