Usine V5.08
[5.08]
Another important release which fixes most of reported problems in the V5.
This version must be download especially if:
- you use the VST version: the vst engine has been deeply modified.
- you are under WinXP with touch-screen mode activated in the setup.
fixed bugs
- VST version : various hard crash bugs at the start-up
- VST version : New VST setup panel
- VST version : the VST buffer size can be adjusted in the setup
- USER modules aren't correctly initialized
- under XP : some troubles with the double click in touch-screen mode.
- Few other details
improvements
- Sub-Patches Control Panels location can be set to IB
fixed bugs
- Few other details
improvements
Alain Vankenhove
OK, whaou, I do take train of Usine news, ...
I have take new version, I want to say to you and If you can say at all Usine Team : it is so great to practice music with this new version, for me it's just I want.
I want to ask you two things, I love Seq Pad Groove, particulary ergonomy, visual... it will be possible to devellope the same thing with 16 or 32 pad and much line and different button, I know it's possible but I have need help, I don't understand a lot of things with patches... other thing, I see and smell Sep PAd is a good base to devellop a general sequencer. If you want to discuss that, I am free, man,
see you,
I have some idea with this program, clap clap clap !!
Alain,
see you,
Alain,
Asus A7C dual core/RME Fireface UC/Axiom 25/MPD 24/Trumpet/BCR2000/FCB1010
you can improve the seq pad by duplicate cells.
senso+++
senso+++
Felix_Petrescu
please make some sort of offline manual
even temporary
even temporary
the pdf versions of the quick-learn and the manual are available for download:
http://www.sensomusic.com/wiki/lib/exe/ ... ine_fr.pdf
http://www.sensomusic.com/wiki/lib/exe/ ... ine_en.pdf
http://www.sensomusic.com/wiki/lib/exe/ ... ual_en.pdf
Felix_Petrescu
thanks big time !!!!
the next version will contain an "off line" help system.
soon.
soon.
La Tenaille
Good new, I will never connect my pro. laptop to the web
Users browsing this forum: No registered users and 185 guests
