how to play just the selected marker
héliouk 6
Unread post by héliouk 6 » 10 Feb 2010, 21:57
hi everybody!
it must be simple...i want to play the marker i want ,only this one. how ?
thanks a lot...
Unread post by nay-seven » 10 Feb 2010, 22:35
something like this ?
héliouk 6
Unread post by héliouk 6 » 10 Feb 2010, 23:10
i didn't express my idea very well:i want to trigg a marker without playing the other parts of the sample,i tried with a play button to command the playing and the marker number,but it play all the sample....the idea is to divide a sample and be able to trigg the part of the division you want,with a step module ,or random...
Unread post by nay-seven » 10 Feb 2010, 23:23
try the compilation-utils1 in the addons/others , there 's something like this..
named :
1sample_4_position to play_button
Unread post by grego mondo » 11 Feb 2010, 16:21
so you have a play trigger that starts at the first marker, right ? and another marker that shows the end ?
can't you get the position of the second marker ( something like 38,5) and make a stop play when pos. is > 38,5 ?
héliouk 6
Unread post by héliouk 6 » 11 Feb 2010, 19:52
yes! i uploaded it as "markers", it seems to work good,i'm gonna try with more samples...thanks guys...
is there a way to make the uploaded image (from uploader menu)appears here? or do i pass through image hosting?
Unread post by nay-seven » 11 Feb 2010, 20:06
kOKaR
Unread post by kOKaR » 05 Mar 2010, 16:18
Hi everybody,
I want to make a similar patch and i've got the same problem.... and i don't understand really what is the solution. I've not found the Compilation_Utils_1, where can I download it, please..?
Unread post by nay-seven » 05 Mar 2010, 18:54
it's an old thread , but here the heliouk6 screenshot :
gurulogic
Unread post by gurulogic » 05 Mar 2010, 20:52
hehe...is everyone making a beat loop reslicer?
I also have another way to play specific slices from a loop in the sampler if anyone wants to try...
This divides a loop exactly by the number of steps.
Fom the output of your step module, use an A*B, B=100 divided by number of steps, and then from the A*B outlet, an A-B, B=100 divided by number of steps. From the A-B outlet you connect to both the Start Pos and Pos inputs. This only works for me in Bar Sync modes with a max record time set to 2x the desired playback length but it works well.
So when do we all compare our beat loop reslicers? ;)
kOKaR
Unread post by kOKaR » 05 Mar 2010, 21:57
Ok.. thanks for answers...
I've try to do the heliouk6's patch, but for me it doesn't work... and also it's not really what i'm thinking about...
What i want it's simply a wave file slice with markers... and each part can be trigger with a play button (play as long as press)...
Roughly it can look like this:
"hs": reading in english it's ok for me but writing is too difficult.. so all appologies for mistakes.."hs"
kOKaR
Unread post by kOKaR » 05 Mar 2010, 23:09
ok.... I'm beginner with usine so I'm trying many way to translate my thing in a patch but for now i failed..! So if somebody want to help me i'm very interesting.
Unread post by nay-seven » 05 Mar 2010, 23:36
hey , kokar
i've just add a little addon , as a first try to your question ( was more easy than a screenshot ) check it and tell me if it can help to begin something :
you move your markers as you want , switch 1 will play marker 1 to 2 , switch 2 play markers 3 to 4 and so..
( you can also use button in place of switches..)
addons/others/NS_4_Markers_Player
kOKaR
Unread post by kOKaR » 06 Mar 2010, 00:04
Thanks a lot Nay Seven, for answer and reactivity!
It works well, however I want to work in "syncmod=playbutton".. I want each button to play when it press and stop when it release..
But thank you for this great begining... I will study it tomorrow in details because I want to really understand how it work.
good evening
KOkar
kOKaR
Unread post by kOKaR » 08 Mar 2010, 22:21
Hello Nay seven, (and everybody of course!)
I worked on the patch (thanks for your begining idea ;-)) and I have got now what I wished... cool!
However they are two things that I don't understand:
1- The reverse function dosen't work... For example what I want is when you press "3rev" sample is play from marker 3 to the begining. For now these functions always start from the end to the marker..,!;,;?
2- When I record stuff from input soundcard, there is always a small decay at the beginig of the sample... I play with asio4all. Normally there is no problem..?.
So except that, it work well... We can play with library sample or record a sample "on the fly". There are two differents way to trigger sample:
-with mouse (or finger): sample is play from marker to the end (or retrigger)
-with midi keys: sample is play from the marker to the end, as long press
When you have play a pattern that you like, you can loop it on the second sampler (with midi learn, to have a great loop)!..
Can I send you the patch..? so If you have an idea (and time!) to correct the reverse button... and after that perhaps we can add it to the add-on, If you want.. Or maybe I can add it as "work in progress"... Let me know..
So thanks for your help.
Unread post by nay-seven » 08 Mar 2010, 23:23
no problem if you want send me the patch..
yan.ledean|at|sensomusic.com
cause I'm not sure to understand, in the last version I've uploaded , if you set marker 1 to 2 for the first switch , in reverse mode this will play marker 2 to 1..normal..?
kOKaR
Unread post by kOKaR » 09 Mar 2010, 07:15
sorry but I not seen your last version.
finaly what I wanted was not really to play a slice (from marker to marker) but rather trigger from marker to end.. i didn't express my idea very well. sorry but let see the patch and you will see.
thanks
r.erorr
Unread post by r.erorr » 13 Nov 2012, 21:04
I know this is an old post, but I have new solution: just touch the slices or slide over right on display
I thought it could be much comfortable for touchscreen
http://www.sensomusic.com/forums/upload ... ver%5D.pat
Unread post by nay-seven » 14 Nov 2012, 00:43
Very cool solution r.error, i can imagine a big patch with several of this ones ! ;)
have you find a way when you add some markers..?
r.erorr
Unread post by r.erorr » 14 Nov 2012, 04:29
Yes, edit markers in real time is not very comfortable. I think markers must be determined by poly, because anyway you will need to apply poly, if num of markers are changed. I don't see different solution in this system. So just change the poly and markers will be changing to too
here smoother visual feedback, and edit markers button
http://www.sensomusic.com/forums/upload ... s_EDIT.pat
Unread post by nay-seven » 14 Nov 2012, 08:30
I don't have study your patch deeply but i was thinking about the inlets poly and apply poly of the current patch setting module but maybe not doable....
r.erorr
Unread post by r.erorr » 14 Nov 2012, 13:16
ah, thanks. . . I haven 't noticed about current patch module :)
http://www.sensomusic.com/forums/upload ... es_V.2.pat
Unread post by nay-seven » 14 Nov 2012, 18:33
really cool job, i like it !
multiphone just send me this link,could be an inspiration source ;)
r.erorr
Unread post by r.erorr » 14 Nov 2012, 21:38
thanks . . .
Yes, ipad sampler is similarly based, and gestural manipulation are interesting.
Users browsing this forum: No registered users and 57 guests
