midi filter "inverse"
gurulogic
Unread post by gurulogic » 10 Feb 2010, 02:56
It would be super handy if the midi filtter module could have a mode that instead of only passing the selected message, it would only block the selected message.
Unread post by senso » 10 Feb 2010, 09:10
it's a good job for a script.
Bsork we need you!!
Unread post by bsork » 10 Feb 2010, 09:20
I've been thinking of various filters, and one of the ideas I have had for a long time is just that. Just haven't got around to it...
I'll do it and include it with the utility pack. It shouldn't take long; copy bits of code and add a NOT here and there :)
Unread post by woodslanding » 10 Feb 2010, 10:53
All of bidule's filters have a 'pass' and 'reject' output. Then they can do double-duty.
-e
Unread post by bsork » 10 Feb 2010, 13:02
I can adapt the pass/reject outputs idea.
Unread post by senso » 10 Feb 2010, 16:59
In fact it was so easy to implement it that it will be in the V5!!!!!
@bsork sorry if you have worked for nothing!
Unread post by bsork » 10 Feb 2010, 18:04
That's great - I have enough other things to do. Haven't been doing anything on this anyway as I've been working.
gurulogic
Unread post by gurulogic » 10 Feb 2010, 18:31
senso wrote:In fact it was so easy to implement it that it will be in the V5!!!!!!
Hooray! Thanks!
I am hoping the pass/reject also works with channel messages? So say that you select channel 1 in the filter it lets all channels except channel 1 pass? (this is unclear in the wiki)
Unread post by senso » 10 Feb 2010, 18:54
yes, it works with channels as well as any other filters
amiga909
Unread post by amiga909 » 14 Feb 2010, 16:25
great to see more midi functionality in v5 :)
if u cant wait: until v5 is out one of my v4 filter scripts should do (i've adapted bidules idea of filtered/passed outputs)
Users browsing this forum: No registered users and 96 guests
