how to set a lenght according to another
héliouk 6
- nay-seven
something like this..?
divise by 1000 to convert MS to seconds , add a multiply
knob must be :
min= 1
max = what you want
prec = integer ( or what you want )
knob must be :
min= 1
max = what you want
héliouk 6
so simple....thank you nay!
héliouk 6
hi again! it's good to record anywhere and be syncronized,but when i want to make all samplers go to the zero position with button sending a zero value,each one go to his zero pos,normal..and no more sync.sniff...
so i 'd like to make all samplers go to the zero pos of the first sampler(base) recorded,each other to his respective position at the moment zero of the base.do you have an idea how to do that?
hope i'm clear...
and happy nouille R everybody!!
hope i'm clear...
héliouk 6
something like this:
the stop play from the master is used to insert a marker in slave, and is stopped after having put just one marker,with the start button i say to master:go to your beginning and to slave:go to the corresponding beginning!
it seems to work with 2 samplers,i 'm gonna try with more...
héliouk 6
héliouk 6
some problems...mmm it doesn't work as well as i want.. see that later
- nay-seven
heliouk , you can also use the uploader menu on this forum to have better quality picture...
héliouk 6
hello nay,in fact your proposition works,but the precision allowed is not sufficient to have perfect sincro:i do my first record,then i do the second,wich is 2 time longer than the precedent,and it begins to be de-sincro from a moment. i think it's because my max prec is x.xxxxx . is there a way to have more precision or to trunc something?
(i'm talking about the beginning of this topic)
- nay-seven
waiting for V5 , have you tried to play with / set the global speed in your global setup/asio tab..?
héliouk 6
i tried,it's better but not that...
- nay-seven
sorrry , not really time right now to look for a solution , but i think about the patch " quantize data " in the time/synchro tab...
maybe try to insert it between the 2 sampler pos inlet or an other..
