midi out in energy-xt
i used to have a license for usine till v3.68 and now i want to upgrade to use it as a vst in ernergy-xt. i tried the latest demo vst, but the midi outs don't work. in usine the "trace midi" function shows output, but i don't receive anything in xt. is it a bug or do i need a special setup? (same problem with v3.68)
Clearscreen
Just had a quick look and I think you're right. The vst is sending midi fine in Live and bidule, but in xt or xt2 there's no midi getting through - very strange!
yes , i confirm too , but I've also test with others plugins that send midi data ( xoxos ones and others ) some works , some don't..
so , maybe it could be interesting to contact energy team...?
Good idea nay but good luck....Since energy xt is affiliated with behringer, they've totally changed their support...nay-seven wrote:maybe it could be interesting to contact energy team...?
Seb.Dub
nay, can you tell me which plugins did not work? i'll post something on the xt board.
example :
circuit , hyperio ,miniseries , populus( http://www.xoxos.net/ )
stepmachine http://www.rozzer.net/wp/?cat=2
BallSequencer 1.5 ( can't even start ..) ( http://upland.no/plugins.php )
all works fine in Usine
one who works : midipads ( http://www.thepiz.org/dl/?p=vst )
thanks nay for the info.
Clearscreen
nah - they're support went dodgy well before that. I remember when there was a bug fix release every week! by the time xt2 was out that'd all changed completely... try it though, you never know.ethnix73 wrote:Good idea nay but good luck....Since energy xt is affiliated with behringer, they've totally changed their support...nay-seven wrote:maybe it could be interesting to contact energy team...?
nay, the plugins you mentioned work fine for me. mind that you have to select the target track and press play to receive the midi on your target.
usine is the only one that doesn't work, so i think it's a problem within usine.
Users browsing this forum: No registered users and 398 guests
