I need help with the sampler
Bovo
Unread post by Bovo » 04 Dec 2009, 01:12
Howdy all! First post here, I'm new to usine but I'm thrilled at the possibilities it offers!
My first purpose is to use it as a live loopstation. I've patched everything well, I think, for I get the sampler to loop properly from inside of usine. My problem happens when I try to control it from my external midi controllers. I assign a controller from my novation X-station, use the midi learn in usine to trigger a button module connected to rec on the sampler. The sampler does respond and starts recording... for 5.80 ms and starts looping... I tried toggle mode on my controller and a few other things but it only loops 5.80 ms of audio... I must be missing something, could anyone help me to find out what?
thanks a lot, looking forward to join this usine community!
Bovo
Unread post by nay-seven » 04 Dec 2009, 07:28
hello and welcome
i suppose you talk about a switch ..?
a button send only one impulse , so not adapted for the rec function...
btw , have you check ' max record time " in the sampler module..?
Bovo
Unread post by Bovo » 05 Dec 2009, 01:15
Oh, I see, I knew it was a dumb mistake... It's working with the switch. I assigned a foot switch to the rec of the sampler, so when I press it it records until I depress it. I'd like to have the possibility to toggle rec on and off so that I don't have to hold it down.
Unread post by nay-seven » 05 Dec 2009, 09:15
on your switch : right click and toggle mode...?...;-)
and , not a big problem , but next time , this kind of question could have a better place in " patching " topics...
Bovo
Unread post by Bovo » 05 Dec 2009, 15:53
thanks for your help, I'm a total noob as you see, I've been through the manual only quickly... Will try and post in the right forum sections...
great, got my toggle right! one step at a time... will be back soon with more questions...
Bovo
Bovo
Unread post by Bovo » 05 Dec 2009, 17:51
Ok, the toggle isn't quite right yet... My connections are as follows:
footswitch assigned to a switch module, plugged into toggle module, plugged in rec in of sampler. It behaves strangely, sometimes working, sometimes not...
Other question: is there a way to crossfade a sample to hide loop points?
Unread post by nay-seven » 05 Dec 2009, 18:45
i don't think about a "toggle " module , but when you do your midi learn by right click , check also " remote mode toggle "..
about loop point have you checked " zero cross " option in the sampler..?
Bovo
Unread post by Bovo » 05 Dec 2009, 19:13
ahhh c'est mieux! Merci beaucoup mon ami!
back to reading the manual...
Users browsing this forum: No registered users and 124 guests
