Global remote learn "range"
Hi another idea.
Would it be possible, for Global remote, to assign a "range" of response for "fader" objects.
Let's take the following example:
- I have a basic midi controller, where a knob sends values between 0 to 127.
- I map it to "track 1 volume", but actually I would love the volume to change ONLY beetween -30dB to 0 dB (instead of the full range from -80dB to +12dB).
Actually I use form the moment "workarounds" (for the above situation a sub patch with "midi in -> small circuit to do the scaling-> Audio volume" for example), or even simpler, on some midi hardware controllers you can do this scaling on the controller itself, that will send from 30 to 100 for instance), but I think it would be great for Usine to have this option.
What do you think?
Rgds,
B.
What do you think?
Rgds,
B.
totally agree
Me too.
I have a controller where min/max values can be set, but the drawback of limiting the sent CC values is that the control gets coarser.
hello,
benjamin+lalo+bsork : the master team?
For you problem, the real question is: how often do you need those features?
Don't forget that any 'hard implementation' has a cost in CPU, memory, etc.
For all this special cases, I have created the interface control objects. Track mixer, global volume, etc...
All those modules have a big advantage: they are flexible and they cost almost no CPU (they are virtual copy of interface objects).
Another question: don't you think that the global remote setup should be totally independent of patch functionalities them self?
Isn?t it better (conceptually) to create a patch as an ?insert? to implement that?
In the add-ons there is a sub-patch with can be very useful (I use it a lot): Kitchen pack/ autoscale. It scales automatically the input signal to fit to the output.
i understand..this is a really good point...senso wrote:For you problem, the real question is: how often do you need those features?
..but sometimes (quite often) having some hard (optional in the setup panel for example) implementation saves a lot of time a t patching sessions...
and they are really really useful and appreciatedsenso wrote:For all this special cases, I have created the interface control objects. Track mixer, global volume, etc...
i think the most important thing is often the "coherence"...senso wrote:Another question: don't you think that the global remote setup should be totally independent of patch functionalities them self?
for example the midi learn works always regardless the active track
the key learn instead works only when the track where the control is , is active...
i think there's should be option for midi learn and key learn to be "globally active" or "active when track is active"
what do you mean?senso wrote:Isn?t it better (conceptually) to create a patch as an ?insert? to implement that?
thanx for the infosenso wrote:In the add-ons there is a sub-patch with can be very useful (I use it a lot): Kitchen pack/ autoscale. It scales automatically the input signal to fit to the output.
have a good day guys
thanx again
lalo
I mean as an insert in the master section.Isn?t it better (conceptually) to create a patch as an ?insert? to implement that?
Good suggestion: option "key global / only on selected track"
thanxsenso wrote:I mean as an insert in the master section.Isn?t it better (conceptually) to create a patch as an ?insert? to implement that?
and also "midi global/only on selected track"...for consistency
Hello,senso wrote:hello,
Actually I had totally forgotten about these modules, after digging a bit in the "interface control" folder, I've definitely found treasures!!! Once again I think usine is really amazing and full of surprises!! Great!
Yes, I agree! More simple this way.senso wrote:Another question: don't you think that the global remote setup should be totally independent of patch functionalities them self?
Well, now that I have these interface control modules, that's what I'm gonna do, that's easy!!senso wrote:Isn?t it better (conceptually) to create a patch as an ?insert? to implement that?
Gonna check that!senso wrote:In the add-ons there is a sub-patch with can be very useful (I use it a lot): Kitchen pack/ autoscale. It scales automatically the input signal to fit to the output.
Rgds,
B.
Users browsing this forum: No registered users and 67 guests
