Multi out from VST?
Kaspar
Unread post by Kaspar » 06 Oct 2009, 18:24
Is it possible to route multiple outputs from the free VST version of Usine?
Can't wrap my head around it...
For an example:
1) I have a track in the VST host (Reaper), that has Usine on it.
2) Inside Usine I have Mobius VST - using 2 inputs and 16 outputs.
I'd like to route these 16 outs to separate tracks in Reaper.
Unread post by nay-seven » 06 Oct 2009, 23:20
but reaper can see only the 2 in and 2 out of the vst version...
Kaspar
Unread post by Kaspar » 06 Oct 2009, 23:28
Is this also true for the commercial version?
Any solutions to change that or work around it?
Unread post by nay-seven » 06 Oct 2009, 23:30
yes , it's the same for the pro version, if i remember well , was a cpu choice...but i'm not senso..;-)
gurulogic
Unread post by gurulogic » 08 Oct 2009, 03:28
Kaspar, are you aware that if you add more instances of Usine VST on another track in your host, they become additional stereo input and outputs for the main instance of Usine? There are up to 16 stereo pairs from/to usine with this approach
Kaspar
Unread post by Kaspar » 08 Oct 2009, 09:04
gurulogic wrote:Kaspar, are you aware that if you add more instances of Usine VST on another track in your host, they become additional stereo input and outputs for the main instance of Usine? There are up to 16 stereo pairs from/to usine with this approach
I am aware of that, but I haven't yet tried it because I thought they wouldn't have the same Mobius VST instance in them.
I'll check it out just in case...
Unread post by nay-seven » 08 Oct 2009, 12:47
sorry , i don't use really the vst version enough to help you with this ...
if you find a good way , could you make us a little tutorial ..?
Kaspar
Unread post by Kaspar » 08 Oct 2009, 15:47
nay-seven wrote:sorry , i don't use really the vst version enough to help you with this ...
Tried it for a couple of hours, but couldn't get the outputs from Mobius' different tracks to separate tracks in Reaper.
Maybe I'm stupid, but this seems to be very difficult (if there isn't a limitation in the free version).
I'll try again later.
If I succeed, I'll make a tutorial - might save somebody a days work ;)
Unread post by nay-seven » 08 Oct 2009, 20:38
ok , i've do a little research and finally see how it works , i've done a little wiki to explain , test it and tell me if it's ok for you .
and feel free to complete / ask
http://www.sensomusic.com/wiki/doku.php ... ere_mobius
gurulogic
Unread post by gurulogic » 08 Oct 2009, 22:01
nay-seven, in your example you don't necessarily need to bus each output from the VSTI to a new track. You can simply add an "Additional Audio Output" module for each additional output you would like to use.
Unread post by nay-seven » 08 Oct 2009, 22:32
yes , you're right , as always in Usine , it's each time more easy than your first idea...;-)
my solution could be useful if you want add effect on each track , gone to update the wiki
Thanks Gurulogic
Kaspar
Unread post by Kaspar » 08 Oct 2009, 23:07
nay-seven wrote:ok , i've do a little research and finally see how it works , i've done a little wiki to explain , test it and tell me if it's ok for you .
Thanks! It works as intended.
Am I right that Usine allows only 8 mono outputs (4 stereo)?
Anything above that is marked as "invalid" output.
gurulogic
Unread post by gurulogic » 08 Oct 2009, 23:23
Kaspar, perhaps the 4 stereo outputs is a limitation of Usine free? I can't say for certain in Reaper but in Live I can use 16 stereo pairs.
Kaspar
Unread post by Kaspar » 08 Oct 2009, 23:32
gurulogic wrote:Kaspar, perhaps the 4 stereo outputs is a limitation of Usine free? I can't say for certain in Reaper but in Live I can use 16 stereo pairs.
Yes, perhaps so. I don't think Reaper is the limitation.
Users browsing this forum: No registered users and 120 guests
