Usine 4.22f
Announcements
Unread post by senso » 12 Sep 2009, 13:36
Usine [4.22f]
Must be downloaded to replace the 4.22e
fixed bugs
- save problems in the "channel" parameter of the create midi module
[4.22e]
intermediate update. You can skip it if everything works on you system.
fixed bugs
- small bug in the channel parameter of the create midi module
- the grain sampler now works in “loop+next” sample
improvements
- the max number of VST parameters in now 1024
- small synchro problem with the Molar VST
- new "Midi Unpack" script.
Unread post by nay-seven » 12 Sep 2009, 21:56
Thanks for the fix !
ethnix73
Unread post by ethnix73 » 13 Sep 2009, 11:34
thanks!
Seb.Dub
siegfried
Unread post by siegfried » 13 Sep 2009, 23:34
thank you!
Sorry for my bad english :/
Unread post by grego mondo » 14 Sep 2009, 21:22
super !!
Unread post by woodslanding » 14 Sep 2009, 23:07
did you get a chance to zero the inputs of audio input busses when they are disconnected?
If not, I suppose I will wait to upgrade....
gurulogic
Unread post by gurulogic » 15 Sep 2009, 02:17
Thanks, Molar syncro seems perfect now :-)
Unread post by senso » 15 Sep 2009, 08:58
this problem will be solved in the next major release.
please, it's not really an argument for me! This kind of modification can take more than 3 days to be implemented securely: development, test, package, etc.
Sometime modifications cost nothing : have 1024 VST parameters instead of 512 takes maximum 10 seconds. And others can take much more than appears, and yours needs a deep refoundation of the internal buses system.
So I must include it in a global development perspective, even if I loose an upgrade!
Unread post by woodslanding » 18 Sep 2009, 07:35
sorry-didn't mean to sound snippy!
You said it was an "easy fix" when I first brought it up..... I'll keep waiting.
--e
Users browsing this forum: No registered users and 183 guests
