I would like to use windows scrollbar in my display module.
I need the handle to the module's window to set it...
How can i get it?
Or there's maybe another way?
thanks
scrollbars
- senso
actually no way to get the form handle.
We'll correct it in the next SDK release.
martignasse
Hi Gizzeta,Gizzeta wrote:Hi,
How can i get it?
thanks
It's funny that recently, i was testing some things around that.
It's possible to store the HINSTANCE of the module in a global variable by adding a DllMain function in the cpp file, like that :
Code: Select all
HINSTANCE hInstModule = NULL;
BOOL APIENTRY DllMain( HMODULE hModule,
DWORD ul_reason_for_call,
LPVOID lpReserved
switch (ul_reason_for_call)
case DLL_PROCESS_ATTACH:
hInstModule = hModule;
case DLL_THREAD_ATTACH:
case DLL_THREAD_DETACH:
case DLL_PROCESS_DETACH:
break;
return TRUE;
}The big limitation of this hack is it's using global variable, so limiting you to one instance of you'r module in usine
Hope it help
- senso
good tip Martin!
martignasse
I think it's should be a temporary hacksenso wrote:good tip Martin!
(I found this to be able to open a modless child window for a module, like the array set module)
Yes, handle and/or instance of the module should be provided by usine.senso wrote:actually no way to get the form handle.
It's more secure and powerfull.
