How to bypass a VST when switching to another?
MikeyJ
Unread post by MikeyJ » 09 Aug 2009, 18:52
Hi All,
I'm pretty much a Usine noob. I'm a guitarist and am setting up to run amp simulators from a laptop. I currently have an instance of Amplitube2 on track 1 and an instance of Guitar Rig 3 on track 2. I'll be using Preset Managers with them and there are times where I'll need only one active, but sometimes both. How do I automagically bypass one when switching to the other? I'm assuming this saves CPU like it does in Bidule?
Thanks!
Mike
Unread post by nay-seven » 09 Aug 2009, 20:33
hello and welcome !
you can use the data bus for this and and a math / logical/ not (a ) :
the 2 bus module must have the same name
RoyG
Unread post by RoyG » 31 Aug 2009, 16:21
Nay, your suggestion is great if I only need one track bypassing another, but when I want 4 tracks - each one bypassing all others when activated, using SendBus/GetBus as you've showed causes endles loops.
How do I solve that?
Roy
Unread post by nay-seven » 31 Aug 2009, 18:30
here a way , inspired by 23fx on an other topic...;-)
built this one ( can be adapted to more switch )
23xx say about it :
this might not be the only/best solution but this seems to work well for 2-15 switches.
each switch will output 2-3-4-5-6 to the selector that keep the last pressed switch number and send back to the dispatcher that have "set to 0" enabled, so it will switch off all the others, (add constant 1 on input).ps( I don't use input 1 because it will be the default output when switch are off, that's also why it's need to start from 2 , for the selector to select the 2nd
and put this one in each track ( just rename bus as : track 2 , track 3 and so...
here , the bus are linked to the mute , but you can use it to bypass a vst or what you want..
ethnix73
Unread post by ethnix73 » 31 Aug 2009, 19:15
You could use also the internal usine message:
Seb.Dub
Unread post by nay-seven » 31 Aug 2009, 21:51
can you explain more ethnix...?
ethnix73
Unread post by ethnix73 » 31 Aug 2009, 22:07
Yes, my answer was rather minimal ;)
the first button (send msg1) triggers the first Usine msg module. A value of 1 is sent to the first bus, and 0 to the others.
the second button (send msg2) triggers the second Usine msg module. A value of 1 is sent to second bus, and 0 to the others. aka:
TARGET_PATCH SEND_PATCH
SET_VALUE 1 1 0
SET_VALUE 2 2 1
SET_VALUE 3 3 0
SET_VALUE 4 4 0
And so on, for the others button and Usinemsg...
Then, you can put a getbus module in each track (as in your second screenshot in your last post), or link a getbus module directly linked to a vsti...
So each button activate a vsti and bypass the others.
Seb.Dub
Unread post by nay-seven » 31 Aug 2009, 23:08
great ! thanks , works fine !
will add this to the next "utils compilation " for sure .
and to add a little precision for those who want different name or want understand more :
be careful to understand the difference between the name of the in of the module and his proper name for IML :
ethnix73
Unread post by ethnix73 » 31 Aug 2009, 23:57
The idea come from the drummy and roller sequencer patch made by mr Senso himself...
Seb.Dub
RoyG
Unread post by RoyG » 01 Sep 2009, 08:40
Thanks a lot guys!
It does not seem to work for me. Is it because I'm using the free version (can't edit scripts)?
ethnix73
Unread post by ethnix73 » 01 Sep 2009, 11:53
This patch doesn't use script royg, but the Usine message module. He's in the interface control folder...Double click on it to edit. You got to remane your Getbus modules accordingly to the sendbus names.
Seb.Dub
RoyG
Unread post by RoyG » 01 Sep 2009, 12:22
Are you sure? I did exactly what's shown on your posts but I get nothing when I push the buttons. I'm also getting a message saying: "Error - you can't edit sub patches and scripts in the free version" when I double click the usine-message module even though it enables me to write the text you told me to.
What am I missing?
Should the modules be in a saparate track from the vsts?
Again it seems like everything is going into an endless loop where I cant press any button. Does the order in which I do things matter?
Thanks again
Roy
ethnix73
Unread post by ethnix73 » 01 Sep 2009, 12:51
Just tried in the free version, and yes it doesn't work. It might be a limitation from the free version.
Seb.Dub
RoyG
Unread post by RoyG » 01 Sep 2009, 13:00
OK. thanks a lot for your help. I guess it'll have to wait until I decide to buy the full version.
Unread post by nay-seven » 01 Sep 2009, 17:31
or use the 23fx method with dispatch and selector....
Users browsing this forum: No registered users and 148 guests
