Get control-alt-shift state
Gizzeta
Unread post by Gizzeta » 25 Aug 2009, 17:50
Is there a way to always get the control, alt and shift state in a module, not only when the mouse is on the module panel?
thanks
Unread post by senso » 25 Aug 2009, 22:47
yes when the procedure MouseMove (void* pModule, TShiftState Shift, int X, int Y) is called Usine fill the ShiftState in the 'Shift' parameter.
But there is an error in the Userdefinitions.h file
Code: Select all
// keys state modifiers
// used in MouseMove, MouseUp and MouseDown functions declaration (see end of file)
 typedef enum TShiftState {
	  ssShift,
	  ssAlt,
	  ssCtrl,
	  ssLeft,
	  ssRight,
	  ssMiddle,
	  ssDouble
must be replaced by
Code: Select all
typedef DWORD TShiftState ;
static DWORD const ssShift = 0x1
static DWORD const ssAlt = 0x2
static DWORD const ssCtrl = 0x4
static DWORD const ssLeft = 0x8
static DWORD const ssRight = 0x10
static DWORD const ssMiddle = 0x20
static DWORD const ssDouble = 0x40
so you can check if 'Shift' contains one or several values above.
Code: Select all
if ((Shift & ssCtrl) !=0) {..} //means that the Ctrl key is pressed
This error will be 'officially' corrected in the next SDK release.
Gizzeta
Unread post by Gizzeta » 25 Aug 2009, 23:03
yes, i found the error, but in this way I get the shift state only if I move the mouse (on the window?).
I would like to get the shift state even if I don't move the mouse...
Unread post by senso » 26 Aug 2009, 10:19
for that you have to query directly the keyboard state like:
Code: Select all
  BYTE state[256];
    #define KEY_PRESSED(key) (state[key] & 0x80)
    GetKeyboardState(state);
    if (KEY_PRESSED(VK_CONTROL) && KEY_PRESSED('C')) {
        // CTRL-C pressed
Gizzeta
Unread post by Gizzeta » 26 Aug 2009, 16:40
Thanks!
martignasse
Unread post by martignasse » 26 Aug 2009, 16:54
senso wrote:for that you have to query directly the keyboard state like:
Code: Select all
  BYTE state[256];
        // CTRL-C pressed
useful infos, have to put this on the wiki
thanks senso
