plugin wrapper source code
Unread post by sm_jamieson » 21 Jun 2019, 17:06
Does anyone know if the code in the SDK e.g.
Sensomusic Usine SDK HH3-7.01.006modulesPluginWrapper-juce_5 v2
is the actual code of the plugin module included with Usine.
Or is it just an example ?
Simon.
Unread post by sm_jamieson » 27 Jun 2019, 15:25
OK, I compiled modulesPluginWrapper-juce_5 v2.
This does not seem to be the actual version included with Usine, since it does not place the VST interface in a window with save/load bank/preset buttons at the top. The window only contains the VST interface itself.
Simon.
