Posted: 09 Sep 2018, 17:39
I put some debug in the Chunk routines, as follows
on Module load
onGetChunkLen called, is_preset = 0, size calculated as 604
onSetChunk called (loading), size 612, is_preset = 0
on Module save
onGetChunkLen called, is_preset = -1, size calculated as 620
onGetChunk called (saving), is_preset = 1
onGetChunkLen called, is_preset = 0, size calculated as 620
onGetChunk called (saving), is_preset = 0
on Preset load
onGetChunkLen called, is_preset = -1, size calculated as 612
onGetChunkLen called, is_preset = 1, size calculated as 612
onSetChunk called (loading), size 620, is_preset = 1
onPreset save
OK, got to go, I'll expand on this later !
on Module load
on Module save
on Preset load
onPreset save
