In the scripting language, you have:
ProcessIDLE
This procedure is called at the setup refresh speed (around 25ms or 50ms). It's the place where you do calculation which doesn't need a fast speed, IML or graphic stuffs like SendInternalMsg (see bellow).
Why is there not a similar thing in the SDK ?
I have a large update process (recreating a tree for menu display) that is causing problems in onProcess(). How can I draw it in the non-audio thread in an SDK user module ?
I suppose I could do it before redrawing in onPaint() if a flag is set but that seems like a bad solution.
Also, in a SDK user module can the callbacks be set like they can in scripting, like this quote from the scripting reference:
The callback is provided at messages rate, typically every 25 or 50ms depending on the setup refresh speed.
To ensure a faster callback (immediately after the inlet has been modified) use the SetFastCallBack procedure describe bellow.
Simon.
