MIDI Out
nelson
Unread post by nelson » 04 Jan 2009, 20:31
I have function that once a cycle sends to midi output of module some midi message.
Its working, mesage is changing once a cycle .. but ... its all the time transmited thru the wire, not only once a cycle.
Question : what midi message is idle message, or how to send message and 'clear' midiOut parameter ... it cant be 0.. i don't know...
help :)
Unread post by bsork » 05 Jan 2009, 08:42
There is now such thing as an "idle" MIDI message.
I'm not sure if I understand what you mean when you say it is changing vaue as it should, but transmitted more than once per cycle/block. MIDI data (except sysex) are sent as arrays of MIDI records, and if you want only one value per cycle, you should set the length of the array to 1 and update only element number 0. If you want to clear the array (= no MIDI message), set the length to 0.
