How can I create an input like in the A*B module?
I'm saying an input without prefixed limits and if there's no cable connected I can double ckick on the module and type a number in.
I tried with a DataField type with ReadOnly false, but the number is not stored in the field.
Input type
- senso
sorry to answer so lately, I was on the road
you can set
ParameterType = ptDataField.
also set
in the
<float.h>
they are several definitions
#define FLT_MAX 3.402823466e+38F /* max value */
#define FLT_MIN 1.175494351e-38F /* min positive value */
so you can set your parameter to
minValue = FLT_MIN
maxValue = FLT_MAX
you can set
also set
in the
<float.h>
minValue = FLT_MIN
maxValue = FLT_MAX
