I can't find anything about OSC in the SDK
would it be possible to build a module that send multitag OSC message from the SDK ?
thanks
multi format OSC
martignasse
hey olivar,
the OSC system isn't exposed in the SDK at all
and i think it's not a good solution to try to go this way
if multitag is the "ultimate/last" functionality missing about OSC, a "feature request" is the way to go ?
martin
martin
I spend last evening building a sub patch with arrays, strings and udp send and few other modules but not yet tested on my HW OSC server.
I'll post it asap
I'll post it asap
Users browsing this forum: No registered users and 1 guest
