Altering Number of Parameters In User Module
caco
Unread post by caco » 08 Feb 2011, 20:02
I am currently programming a new user module in which it would be advantageous to be able to alter the number of parameters the module contains.
I can use the test query system to be able to set the number of parameters when the module is first created but ideally I would like to be able to add/remove/change parameters during the module's life time. Is this possible? I suspect not from reading through the SDK code but thought I should ask incase I have missed anything :)
caco
Unread post by caco » 10 Feb 2011, 13:09
I'll take that as a no then :)
Unread post by senso » 10 Feb 2011, 13:39
I understand you're request, but actually it seems to be impossible in Usine.
I know that I have to implement this feature in Usine with "built-in modules " , and consequently in the SDK with "user's modules".
It will be, I hope , in the next major release.
caco
Unread post by caco » 10 Feb 2011, 14:16
That would be an awesome addition to my user module and I look forward to its addition to the SDK.
Until then, I will just hardcode a fixed set of inputs/outputs into my module and structure my code in a way that can be altered in the future.
Thanks for the reply Senso
Users browsing this forum: No registered users and 76 guests
