VS.NET 2010
mrlucmorin
Unread post by mrlucmorin » 13 Apr 2010, 06:50
Hi all,
Being new to Usine and its SDK, I wonder if I can go ahead and use VS.NET 2010 (now that it's been released to market) to compile my code, or if I should stick to 2008 for now.
Also, there doesn't seem to be any SDK specific docs (or I'm being blind ?).
In any case, it should be fun to learn :-)
Regards
Unread post by nay-seven » 13 Apr 2010, 09:17
welcome mrlucmorin
sorry can't answer you about vs.net 2010 , but I'm sure some specialist will answer you soon
about documentation , check the manuals page :
http://www.sensomusic.com/wiki/doku.php
mrlucmorin
Unread post by mrlucmorin » 13 Apr 2010, 13:36
Hi nay-seven,
Thanks for the pointer.
Unread post by senso » 13 Apr 2010, 18:33
Normally the code generated with ns.net 2010 is compatible with Usine.
A user module is a 'basic' dll.
senso+++
