PCHAR question
Gizzeta
Unread post by Gizzeta » 20 Jan 2010, 00:59
Hi
I would like to do an object whit N out.
To do this I define the number of output in the .h like this
Code: Select all
#define NUM_OF_OUT 24
then I allocate an array of TEVT*
Code: Select all
TEVT*	pOut[NUM_OF_OUT];
in the .cpp I write
Code: Select all
void GetParamInfo (void* pModule,int n, TParamInfo* pParamInfo) {
	if&#40;n < NUM_OF_OUT&#41;&#123;
		pParamInfo->ParamType		= ptArray;
		pParamInfo->Caption			= "Out";
		pParamInfo->IsInput			= false;
		pParamInfo->IsOutput		= true;
	&#125;
and
Code: Select all
void SetEventAddress &#40;void* pModule, int n, TEVT* pEvent&#41; &#123;
	TMyModule* pMyModule = &#40;&#40;TMyModule*&#41;pModule&#41;;
		pMyModule->pOut&#91;n&#93;   = pEvent;
	&#125;
it works, no problem.
Now I would like to change the Caption of each out like this: Out1, Out2, ..., Out24.
How can I do it?
pParamInfo->Caption is a PCHAR type, how can I manipulate a string like this?
Thanks for help
martignasse
Unread post by martignasse » 20 Jan 2010, 13:25
Hi Gizzeta,
PCHAR is a plain old pointer to char (char*)
so you can do something like this :
in your module class member definition
Code: Select all
PCHAR OutNames&#91;NUM_OF_OUT&#93;;
in your module constructor
Code: Select all
for &#40;int n=0;  n < NUM_OF_OUT; n++&#41;
&#123;
    OutNames&#91;n&#93; = new char&#91;STRING_BUFF_SIZE&#93;;
    sprintf_s&#40; OutNames&#91;n&#93;, STRING_BUFF_SIZE, "Out%i", &#40;n +1&#41;&#41;;
&#125;
in GetParamInfo
Code: Select all
void GetParamInfo &#40;void* pModule,int n, TParamInfo* pParamInfo&#41;
&#123;
	&#123;
        pParamInfo->Caption     = &#40;&#40;YourModule*&#41;pModule&#41;->OutNames&#91;n&#93;;
	&#125;
&#125;
in your module destructor
Code: Select all
&#123;
    if &#40;OutNames&#91;n&#93; != NULL&#41;
    &#123;
        delete&#91;&#93; OutNames&#91;n&#93;;
    &#125;
&#125;
not tested, but it should do the trick
martignasse
Unread post by martignasse » 20 Jan 2010, 15:51
or even more simpler/safer with the use of the STL :)
in yourmodule.h
add includes
Code: Select all
#include <string>
#include <vector>
and a vector in your module class
Code: Select all
class TYourModule &#58; public TUserModule
&#123;
    std&#58;&#58;vector<std&#58;&#58;string> m_vectOutCaptions;
&#125;
in yourmodule.cpp
add includes and namespace use
Code: Select all
#include <string>
#include <sstream>
#include <vector>
using namespace std;
and in GetParamInfo()
Code: Select all
&#123;
    // make convenient pointer to the module
    TYourModule* pYourModule = &#40;&#40;TYourModule*&#41;pModule&#41;;
    // the param name
    stringstream Stream;
    Stream << &#40;n + 1&#41;;
    pYourModule ->m_vectOutCaptions.push_back&#40;string&#40;"Out "&#41; + Stream.str&#40;&#41;&#41;;
    &#123;
        pParamInfo->Caption     = &#40;PCHAR&#41;&#40;pYourModule ->m_vectOutCaptions&#91;n&#93;.c_str&#40;&#41;&#41;;
    &#125;
&#125;
Gizzeta
Unread post by Gizzeta » 06 Feb 2010, 13:04
It Works,
Thanks!
anbd
Unread post by anbd » 23 Mar 2010, 15:23
Users browsing this forum: No registered users and 115 guests
