not resizable Panel
Gizzeta
Unread post by Gizzeta » 25 Aug 2009, 18:29
...and is there a way to make the module panel not resizable by the user?
pansoul
Unread post by pansoul » 25 Aug 2009, 19:57
Sorry Gizzeta if i post on the same topic without response but i have a question about the same subject
with drawpad example for example if if put
pModuleInfo->DefaultWidth = 400;
pModuleInfo->DefaultHeight = 600;
instead of
pModuleInfo->DefaultWidth = pMasterInfo->PanelWidth;
pModuleInfo->DefaultHeight = DEFAULT_MODULEHEIGHT;
and that i put the module in Interface builder mode the size is not 400*600 but is the same that in control panel mode
is there a way to change that
thanks
Unread post by senso » 25 Aug 2009, 23:00
@guido:
actually no way : the panels are supposed re-sizable by users.
we'll think about a flag to make the panel size fixed. I hope soon.
@pansoul:
the default size is managed by usine in order to fit with the default control panel size in grid mode. Actually there is no way to change this behavior.
but as this pb is very connected to the @guido's question, I hope we'll finf a solution soon.
