master section
martignasse
Unread post by martignasse » 07 Aug 2008, 10:05
hy,
I came across something strange yesterday, and i need a confirmation.
The manual say about the master section
If the insert patch is empty, it does nothing (audio thru).
Ok, verified. but after, i made a patch with nothing but two 'audio in' and two 'audio out', but disconnected.... and it's alway's audio thru !
Fortunately, if i connect a 'volume' module between 'audio in' an 'audio out' and put the gain to -inf, it's ok, it work as intended and i have nothing on outputs.
Conclusion : All 'audio in' and 'audio out' have to be connected for the master section to break his 'audio trhu' comportment.
Can you confirm ?
Is it normal, for me, it's kind of illogic.
Unread post by senso » 07 Aug 2008, 10:19
yes totally right
martignasse
Unread post by martignasse » 07 Aug 2008, 11:02
ok, thanks,
at least, i'm not mad, now i understood this ;-)
