Is there a way to change fixture's dimmer number other than by modifying directly in the light plot? Using IML, script, or a simplier way if exist.
I'd like to do a kind of matrix with which I can easily affect a dimmer number to a channel. Equivalent to a "patch électronique" in french light designer language:-)
Fixture's dimmer number
Here's a simple array answer !
Can be expanded to as much faders and fixtures you need
Hi Olivar,
Thank you for your help. But that's not what I need, I guess my explanations were not clear.
I'm wondering how to change fixtures parameters channels from a patch, instead of opening the light plot and the corresponding fixture inside .
For example, in your workspace the 46HP1 fixture is from 8 to 11 and I'd like it from 56 to 59. Is it possible to do that?
Thanks a lot
Thanks a lot
I'm affraid it is not possible, better ask Senso !
That's what I was afraid of...
I'll ask him.
Thank you anyway
I'll ask him.
Thank you anyway
No problem, This patch will be recycled for a synthesiser matrix anyway
I just loved the idea of multiplying by matrix array
