Automatic Save name in sampler
Unread post by cmodica » 02 Feb 2008, 19:00
I'd like to save my rec file in sampler module with an automatic name with increment numbers. For exemple, REC_0001, REC_0002, REC_0003 ....
I need it in a module that record automatically 10 sec of incoming sound each time it happens something on the Audio In.
Everythink works fine with a "save rand" but i have a lot of file and it is not easy to manage them ....
(I hope it is clear .... :/ )
Do you have an idea ?
Unread post by senso » 03 Feb 2008, 11:19
Actually, there is no way to set a prefix name to 'save random' function in the sampler.
I can think about and try to find something.
Unread post by cmodica » 03 Feb 2008, 11:36
OK, thank you Olivier.
