Page 1 of 1
Set color array value?
Posted: 23 Aug 2024, 21:12
by woodslanding
Can't figure out how to do this.... there is a set value for GA color, but that is not working for me....
EDIT: checked the manual, needed to create the GA module, working now.
Re: Set color array value?
Posted: 25 Aug 2024, 01:26
by SylvainT
You don't need a pass if change before the GA Set, it is included in the module by default. It can be deactivated if you need to.
