Page 1 of 1
Help for a simple patch: Convert an audio impusle into an midi trigger
Posted: 28 Feb 2024, 08:46
by jules wysocki
I'm new here so I have a newby question for you.
I need to use contacts mic to trig a sampler when I hit them (Probably 2 mics so to audio input)
I know that it possible to convert this audio impulse into a midi note to play and stop a sampler.
Could you help me to find the perfect object to do that?
Many thanks for your help.
Jules.
Re: Help for a simple patch: Convert an audio impusle into an midi trigger
Posted: 28 Feb 2024, 15:38
by titl
You can use audio analysis peak detector or beat follower and generate a midi note on with midi generator note on use trigger input), and after filter this note etc...
Posted: 28 Feb 2024, 17:20
by rlgsbt
here is a very simple example
audio to MIDI note.wkp
you can also use "Analysis Audio to MIDI 2" module if you need to get midi notes by frequencies
