VST3 Kontakt 7 does not work
Unread post by sm_jamieson » 09 Jan 2024, 01:31
Using the latest Usine Win 5.2.231211
If I try to add the Kontakt 7 (vst3) plugin to a patch, it locks up Usine. After 5 minutes I gave up and killed Usine.
Pianoteq 8 VST3 loaded after over a minute.
Lounge lizard VST3 loaded straight away however.
I have normal VSTs for everything except Kontakt 7, which is VST3 only, so I have no choice.
What is the state of VST3 support in Usine ?
I do hope Usine won't fall behind in support of these vital things.
Anyone had any idea, else I'll have to raise a bug report.
Simon.
Unread post by senso » 15 Jan 2024, 10:30
The next major release will solve many issues on VST and VST3
Unread post by sm_jamieson » 01 Feb 2024, 09:49
I can confirm that Usine HH6 loaded Kontakct 7 VST3 OK.
Great stuff.
Thanks all.
