Page 1 of 1
Reset sends
Posted: 28 Oct 2023, 18:03
by Gilsornette
I use a lot of "sends" from one rack to another, and I often apply a controller remote to them.
And sometimes I have suprises when loading a workspace with one of these sends that has been saved at full...
Is there a way to send a reset to these sends on the opening of the wkp?
Thank you in advance.
Re: Reset sends
Posted: 01 Nov 2023, 08:42
by oli_lab
Maybe you could reset whatever is producing the data going in the bus ?
Re: Reset sends
Posted: 02 Nov 2023, 16:41
by Gilsornette
Thank you for the advice but I'm not using busses, only "rack to rack" sends.I don't know if it's clear.
Re: Reset sends
Posted: 06 Nov 2023, 13:22
by oli_lab
Oh, I see.
What I do:
When having multiple patches in a rack that I with to switch on an off, I make a top patch with all the controls then send them to the various patches
Home it hélas
Re: Reset sends
Posted: 06 Nov 2023, 15:04
by Gilsornette
Hello again,
I understand this and use it also when needed, but in this case I want the sends (in the rack output) to be reseted.
And it seems maybe not possible...
Re: Reset sends
Posted: 07 Nov 2023, 09:01
by cmodica
It is true that the ON/OFF states of the sends output in the rack are not stored in the Rack Preset.
The gain, mute, solo, pre state are stored in the Rack Preset but not the ON/OFF.
It should be a good suggestion for the future update!
Re: Reset sends
Posted: 09 Nov 2023, 10:06
by SylvainT
You can find a workaround with switches and binds.
Then, I answered in the other post.
Best
Re: Reset sends
Posted: 09 Nov 2023, 14:13
by cmodica
Yes, i had forgoten that but i used switches and binds for this kind of thing.
Re: Reset sends
Posted: 10 Nov 2023, 08:45
by Gilsornette
@cmodica and Sylvain T: thank you for your help. For now , I'll manage with switches and binds.
