large panic button
large panic button
Unread post by sm_jamieson » 26 Jul 2022, 21:09
A quick question. The Panic button that sends all notes off on all midi channels is quite small.
What is the simplest way to have a larger panic button wherever you want in the workspace ?
Simon.
Unread post by grego mondo » 27 Jul 2022, 16:39
There's an inlet PANIC in the Module/Interface Control/Usine Panels/Usine Master Settings
that allow you to control it from any button or bus ...
Hope it helps
Ariajazz
Unread post by Ariajazz » 30 Jul 2022, 00:56
This is what I did. I placed a large button in IB (or wherever you want) attached to a create midi module which sends cc midi message to Usine's panic button via lear midi command.
Users browsing this forum: No registered users and 84 guests
