Page 1 of 1
Plugin controlling knobs
Posted: 29 Apr 2021, 22:30
by Ariajazz
Hi all. I do have several Usine knobs that control different parameters of a plugin (Guitar Rig 5). Different presets are stored in GR5 preset manager sytem. The thing is that when these presets are recalled within GR5 the knobs in Usine stay in the last position they were, in other words, they don't move accordingly to the position of the preset recalled. Is there any way to make these knobs get the position of the preset recalled?
Re: Plugin controlling knobs
Posted: 30 Apr 2021, 11:05
by senso
maybe you can use the "pass if has changed" module as explained in https://www.brainmodular.com/manuals/hh ... se-plugins
Posted: 02 May 2021, 15:07
by Ariajazz
Thank you very much for your help. I had to add another Pass if change module in between the know that goest to the plugin in order to work properly.
