Create folder via the script "File Write Text File"
Posted: 16 Feb 2021, 19:15
When I use the module "File Write Text File" (it's a native script), I connect the "folder" inlet to a custom path name which is "dynamic" (it depends on the date). But I noticed that since the folder does not exist, the script cannot create a text file accordingly.
Is there a way to create the right folder at the right path (defined by the "folder" inlet) before creating the text file, please?
By the way, I take advantage of this thread to ask you if there is a way to enter a simple "space" character in a concat string inlet? (in the meantime I use an underscore character but it's not convenient). More generally, out of curiosity, what about other Unicode characters?
creal.
creal.
