Page 1 of 1
latch mode in sampler recorder ?
Posted: 08 Nov 2020, 11:58
by nbremaud
It's really a newbie question but I dare asking it (sorry if i missed something obvious) :
I would like the sampler recorder module to work as follow :
when I press the rec button, i would like the recording to start on the first beat on the next bar (instead of starting when the rec button is pressed).
And same thing for the play loop button.
Please, can someone give a clue about that ?
Re: latch mode in sampler recorder ?
Posted: 08 Nov 2020, 14:32
by grego mondo
I'd use a switch for rec to activate a pass flow getting a master sync cycle trigger to set on another switch recording
and another switch for play to activate a pass flow getting the master sync cycle trigger (setting off that play switch) to play the sampler.
It's in that
quantized rec & play.pat
hopping it will do the trick
Posted: 08 Nov 2020, 16:48
by nbremaud
Thanks a lot for the quick help !
I'll try this and tell you if it worked for me.
Posted: 09 Nov 2020, 20:30
by joffo78
Simpler : activate quantize on beat on midi button or switch propriety
Posted: 10 Nov 2020, 11:38
by nbremaud
Thanks joffo 78, it's a lot simpler indeed.
And a big thanks to grego mondo too, your patch works well and, above all, it allowed me to make a big step forward in understanding usine and patches.
