Is there a possibility to have buttons in control panel or interface panel that select the Audio In on the fly.
For exemple : 3 buttons. When i press In 1 it select Audio In 1, When i press In 2 it select Audio In = Track 3, When i press In 3 it select Audio In = Aux 1 ....
Thank you
Select Audio IN
martignasse
hello cmodica,
For what you try to do, you can use the module :
"module/interface controle/usine panels/Mixer Track Input"
the "in" slot let you choice the input for the chosen track, by default (ctrl+drag) you plug a combo box control, but you can use a slider too, or even a more complex selection system.
hope it help
hope it help
- cmodica
OK thank you, i will try it.
