How to control a DMX fog machine?
Posted: 08 Sep 2020, 17:40
I use Usine to control interactive sound design and music, as well as video and lights at the same time. All works like a charm but I have a problem concerning the fog machine. It only accepts one DMX channel, that corresponds to the power of fog flow (0 = no fog blown out, 127 = max power). I succeeded to perfectly control the fog machine from Freestyle DMX but not with Usine. I put this very simple patch:
It works a little bit because the fog machine blow one second and stops, but not at its full power (even if I send a 255 value, ie "1" with from the fader). Maybe there is specific config to control fog machines? I didn't find any fog machine preset in the fixtures presets of Usine.
In the fixture config, I tried to set V type (I guess VALUES), as well as D type (I guess DIMMER), but I also saw there is another type of data for setting fixtures (the S) in this help page: https://www.brainmodular.com/manuals/hh ... ture-panel I couldn't tell you what S is standing for. Maybe there is other data types?
I also wonder what is the difference between the string placed above the 0-255 line (G in the next example) and the string the one that is placed after the comma (toto), for example "G // D,0,255,toto"?
Thanks in advance,
creal.
Thanks in advance,
creal.
