Is is possible to lock a container contents (switches, faders etc.) so they cannot be modified by mouse or touchscreen etc ?
If not, locking all UI elements inside a patch would do.
Simon.
locking container contents
OK, well putting a transparent object over it does the job.
There used to be problems with keeping Usine "on top" items on the top, so we will see - I'm still on HH3.
- x.iso
usually for UI modules there's 'edition enabled' option which you can disable.
