Page 1 of 1
Send trigger when volume decrease
Posted: 09 Jul 2020, 17:52
by cmodica
Hi every body.
I need to trigger something when the sound decrease. It seems so simple, but i try to explain.
I hit a cymbal that go thru an FX. This FX is very loud and sunddenly it decrease very speed.
I need to trigger something when the sound decrease. But the volume is never the same. I can't work with a db value threashold because the db Value depend of the power of the hit on the cymbal. But the FX is always Loud ans suddenly low.
I try with an envelope follower and array average but it didn't do the job beacause it need a db threshold value.
I think i need something to calculate the difference between loud sound and low sound. When the difference is more than X db, so send trigger.
i try with array without success.
Somethink to store the max db value and when the next value is X db under, it send a trigger...
Thank you to help.
Re: Send trigger when volume decrease
Posted: 09 Jul 2020, 18:51
by SylvainT
Interesting problem.
I will have a look at it later.
But maybe you have something to do with the module "array standard deviation".
Posted: 10 Jul 2020, 09:00
by SylvainT
Maybe it's a solution.
You had to adjust the release time of the two envelop followers according to your sounds, and then the threshold.
All the best
trigger with sound decreasing.pat
Posted: 10 Jul 2020, 19:24
by cmodica
i will have a look to it, and i'll tell you.
Thank you very much.
Posted: 13 Jul 2020, 15:17
by cmodica
It is work. 8)
It needs attention to adjust, threshold and the release time of the two envelop followers, but it seems work.
i will play with it for a reharsal soon. I will tell you.
Posted: 13 Jul 2020, 23:34
by SylvainT
Good news
Enjoy
Posted: 20 Jul 2020, 14:24
by cmodica
It works fine and it is funny to play. When i'll have some free time i'll think about some improvements.
